rchippie
rchippie's Avatar
09.19.2009, 05:24 PM
Originally Posted by DonovanP View Post
I'm running a X1 CRT with 3665 2300 motor on 4s.Now temps is really high on the motor because of the front unloading to much.I only bash and don't race.I have 30k in the center diff right now and not thick enough.Will normal automotive wheel bearing grease work for time being till my 100k diff fluid comes in?And will 100k be enough?
But for now just want to know if the grease will be better than the 30k?
I also run a crt on 4s using a castle/ neu 2200 . I use 25,000 or 30,000 in the center with 5,000 or 7,000 in the FR diff & 2,000 or 3,00 in the RR diff . I have no heat issues at all . I think something else might be causing youe issues .
REAL MEN RUN BRUSHLESS
