Originally Posted by DonovanP
I checked for binding and its free running.I must say we did run on very loose dirt yesterday.Might be why it was running high rpm due to wheelspin or something..
But will grease be thicker than the 30k fluid?
It would depend on which grease you use . I think the very loose dirt you discribed is most likely the cause of your temp issues .
