Originally Posted by Brushless Moose
no, I am driving the buggy easy around a track. I am running 2 4s 3000mah 30c packs in parallel. I ran that with the MMM 2200 combo for 45 mins continuous with no problem, and now I cant run it with the tekin for 7 mins without overheating!
Something sounds off here. 6000mah should not get your 45 minutes with either of these setups.
2200kv motor at best would see 20 minutes on a buggy I bet at least.
The temps say you're geared a bit tall. Do you have a hotwire?
