Ryu James
Ryu James's Avatar
09.21.2009, 10:08 AM
actually i have the 2215 2y, which is 750 kv and i will be running on 10s. so tell me, you think this will be ok? when i bought my motor it seemed like the logical solution for 10s at the time but based on recent experiences and what i know now i would have much preferred a lower kv motor. i have been starting to sell my 1/8 motors and get lower kv options. my temps are usually right in the acceptable range but i like it when things run super cool. i used to think you had to spin the motor at 50k rpm to go fast. i have learned much since then. so anyway, what do you think of the 2y on 10s? MB had the 2y that he fried on 8s and that got very hot on 10s but he had the 180hv castle esc. i have the 240hv castle. not sure if that will matter. but also MB said that he later found that his gears were binding so i am not sure if he tried 10s after clearing that up.
anyway, i could be running mine right now if the damn esc would work. i have it all but finished and wanted to test it out but when i plug in a lipo the esc just blinks red one time and then nothing. anyone have any ideas? i havent been able to hook up 10s yet cuz i dont have the connectors i need to make a series link but i figured if i just plugged in one 5s that would at least let me get my esc calibrated and bind my rx until i can get to LHS later today for connectors. do you think the esc wont come on cuz its only a 5s i tried? does it need to be at least 6s being as it is the hv version?
my ramp is now 95% finished and i have posted several pics on my thread here in the forum. all thats left is add the disc brakes, mud guards, and a couple of finishing touches.anyway, i wanted to get your thoughts on this esc issue and setup.
what is your esc and where did you buy it? does it have braking and lvc?
oh, btw, have you seen these? http://innovativehobby.com/outerwear...hpibaja5t.aspx
this could probably work well for a cover instead of the pantyhose. just a thought. its pricey but i had looked at it. i have been able to use many parts from other 1/5s for my ramp. my outerwears motor cover is actually for a 1/5 gas crank case or something.
http://innovativehobby.com/15scalecr...oahmotors.aspx
Jammin SCRT10 Neu 1512 1y
