Originally Posted by Finnster
How close was the fit?
Which part?
The holes needed to be oblonged (is that a word?) out so the screw would sit flush but once that was done the screws went in straight. The ring gear is real tight on the cup I ran the dremel and a grinding stone around the XL cup a couple times so it was easier to install. They fit into the bulkhead without any modificiation.
