brushlessboy16
brushlessboy16's Avatar
09.22.2009, 01:35 PM
If you have acces to a machine shop or a lathe. Bore a 5mm Hole through an aluminum blank- then turn it down to fit into the CLutch bell. set it with 2 part epoxy or high strength glue- CA might work?]]
Then just make the adapter to stickout of the Clutch bell so you can put a set screw on it
