riverat1540
riverat1540's Avatar
09.22.2009, 10:07 PM
i ran the muggy with 11/46 gearing with the 2200kv 1515 and it was too hot of a setup for both the motor and the speed control in the long run, this is how i sent my mmmv3 in flames just recently, if u are set on running the muggy with this motor i would run a quality 5s 5000mah pack and gear about the same to start. i still want to run 6s however so have opted to run a medusa 80mm can in the 2000kv flavor with a heatsink and fan and see where that gets me it seems to be working well for UnsulliedSpy but my ideal motor for 6s would be a neu 1521 1y/f which is the same as the 1515 1y 2200kv but a longer can for more torque and cooler running less rpms per volt, and easier on the speed control i hope
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
