Originally Posted by slimthelineman
hes right its a "chicken catcher" dont ask why its called that but its used by catv and communications. that is the outside piece which the wire lays inside of and there is a wedge that goes inside to "pinch" the wire so it can be pulled tight and hooked onto something using the wire loop.
I KNEW you would know! I couldn't remeber what they called em.
