aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.23.2009, 02:06 PM
thanks for the input. i think i will be able to run a test today. so is yours actually geared higher than mine? i guess you could gear a lot higher with such a low kv motor and so much power. i am really hoping it works as planned. i really dont want to have go back to the drawing board.
sorry about your mgm. luckily for me i was just over looking things but it sounds like you know what you are doing and chances are the mgm needs to be replaced. idk, i know some guys swear by them. i have never owned one but have looked at getting one several times.
Yeah, mine is geared higher because of the lower KV... But don't hook up your Castle BEC to your 10S, it will fry.. 6S maximum on the BEc, so you'll need a seperate pack for that.. but I suppose you already know this... Your buggy should be rockin' today man.. .Hurry up and post a video...
Originally Posted by florianz View Post
ooops...
well, w/out bec it won't work...
be careful with the ubec/external bec, it has to work for 10s. it also should provide enough amps for the big servos.
eg, the turnigy ubec/bec are quite good.
They do work very good, but I do like the castle UBEC.. I have quite a few of them myself..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
