09.23.2009, 04:26 PM
Welcome to the forums!
I don't believe there are any "out of the box" shafts you can use. So, you'll need to get custom shafts and drive cups from Mike here at RCM, or wherever you prefer. Wherever you go, you'll most likely need to provide exact measurements.
Or, you might be able to modify Revo driveshafts to work. Just remove the booth and cut the parts down for the size you need...
