florianz
09.24.2009, 09:42 AM
Originally Posted by Mystro View Post
I seem to have a meshing problem so i need to make a whole new motor mount design....AGAIN!!
The RCM mount looks good right about now...
that's what I have thought in the first place.
but, a new and solid one is not a problem. just make it a bit "wider", so the mount reaches to the plastic mount of the center diff. you can use the mounting holes of the mechanic breaks, and with two screws the mount is also connected with the diff. like that, meshing is impossible. w. some fresh saw blades, driller etc. it's no big deal at all, but cheap and solid.
