simplechamp
simplechamp's Avatar
09.24.2009, 03:00 PM
Allright, here is the new CC Blower!
It is made of all plastic (seems pretty sturdy), so it's only a fan and shroud, no heatsink. The plug is a standard servo plug with red/black wires (no signal wire of course). The wire is a bit smaller gauge than standard servo wire, would have been nice to have a little bit thicker wire.
The shroud over the fan seems to have an intake of sorts, almost like the blower on the hood of a hot-rod. The top of the fan is open so I'm not sure how functional this intake will be, but maybe there is a reason Castle put it on there. If you look at the way the plastic case is shaped it almost looks like they were trying to make it look like a V8 engine (could just be my imagination though)
The fan uses a DC brushless motor. It's rated for 5V and will draw 140mA at that voltage. The fan model number is YM0503PVS1. It has a small logo on the label but I'm not familiar with it, maybe someone can make it out in the picture.
Now I just have to get my E-revo back together so I can actually test this thing!
