stum
09.24.2009, 05:01 PM
If I could point out two things..
#1 if it's loose enough to come off you want to swap out the end anyway and this will only hide a problem and may lead to control issues that take longer to realize.
#2 if you swap to the RPM true tracks not only do you get a perfect toe in you don't have rear turnbuckles or any of the hassle that comes w/ them; minus the weight as well.
Just my 2c
I do a no pop mod on my 8ight truggy/buggy steering turnbuckles, which is very common racing, but nothing supporting around the plastic ends. I want to know when the ends get loose so I can replace and keep the control and accuracy.
