Ryu James
Ryu James's Avatar
09.25.2009, 11:26 PM
Originally Posted by KaztheMinotaur View Post
Yes. No, other than the binding I told you about.
I did discover that a 200 ounce servo pushing cable brakes seems a lot weaker than a 200 ounce servo running the stock Rampage brakes.
Wheels and tires look good.
I worked on soldering my battery connectors some tonight. I discovered that slip on pencil erasers make a perfect cover for 6mm bullet connectors.
hmm. yeah when i mounted my brakes on the stock plastic parts they worked fine, with the exception of needing to take out a little material to allow full steering throw. the aluminum parts are different in size and shape slightly so its been a little tougher. actually after looking at things again some extended hubs will take care of everything. they need to be extended by about 5mm on each hub though. i dont know if there are any that extend out that far. again i am using 24mm hubs. you know of any? i really like these uberRC hubs. i cant use the darksouls cuz they are round where the discs would be. so i need a hub that is hex shaped throughout.
http://www.davesmotors.com/s.nl/c.88...t.A/id.6349/.f
these uberRC hexes extend by 8mm which is perfect but they only sell them in a set so i would have to drop $200 and then try to sell the fronts. d4mn. didnt really feel like doing that.
Photobucket
Jammin SCRT10 Neu 1512 1y
