09.27.2009, 08:32 AM
+1 to that.
Gearing up for speed runs is fine, but simply gearing up on higher voltage is simply incorrect- if anything you have to gear down to maintain the desired *sensible* speed (assuming you're not doign a speed run setup, hence the higher voltage).
I really would have hoped they would have corrected the manual on this issue, but hopefully someone will point out this flaw to HPI before anymore asshats try to sue them or Castle because they're too stupid to know how to look after an RTR road missile...
