Originally Posted by suicideneil
I wander if you could trace the voltage meter back to somewhere, then rewire it so that it takes a reading more directly (obviously not from the batts directly as it would always be on & draining them down slowly)?
Not sure if that would be adviseable. Easier (and safer IMO) to just remember that the display will read 0.2v lower than the actual voltage, until it gets down to under 3.5v.
Originally Posted by simplechamp
So this means using single cell lipo power could be possible?
I still haven't experimented with the range vs voltage part yet. It would be nice though as no balancer, regulator, or lvc (use radio warning) would be needed. Also, if there is a linear regulator in there, you have to consider the drop-out voltage.
