Originally Posted by lincpimp
Meh, leave your gearing and put 6s on that bad boy!!! You will quickly see if your batteries are up to snuff!
4s setups draw alot on startup, you may need some more lipo capacity to fully cure the cogging. I always ran the c50 motors with med start power and normal timing.
The Test run was done on 4S with 30C/40C 5000mah packs. They weren't even warm afterwards.
I also checked cell balance and it's almost perfect.
