J57ltr
09.30.2009, 10:30 AM
No, If you parallel all VC's you will end up with a .5 ohm load across the briged output, the amp sees half of what it's presented so each side would see a .25 ohm load. You need to series each speaker then run them separately on the rear channels for a 4 ohm load on each side (and the amp will have better control over each speaker. If you run the pair in series again for an 8 ohm load and bridge the amp it will have the same power as single 4 ohm loads on each channel. You can’t parallel the speakers individually because you would have a 1 ohm load on each channel.
Jeff
