Pdelcast
Pdelcast's Avatar
09.30.2009, 11:29 AM
Originally Posted by Emaxx_Quebec View Post
When you say to plug a srevo( steering) in the throttle chanel, you mean once mmm is on or before open it.
When I hook up a servo to the throttle channel to see if it is working correctly, it would not even arm. ( normal I think since the MMM is hook to ch1)
No, just run the RX and servos with a battery. Plug an extra servo into the throttle channel to see what the throttle is ACTUALLY doing.
You don't need the MMM hooked up -- just make sure the servo moves as expected, i.e., when you hit throttle the servo moves one direction, and when you hit brake the servo moves the other direction.
Patrick del Castillo
President, Principle Engineer
