riverat1540
riverat1540's Avatar
09.30.2009, 06:46 PM
you are geared for 47mph on 4s and 60 on 5s not including tire ballooning, i think your system is under too much load to get up to speed if u think it is too slow with a 17 tooth pinion and a 2300kv motor, i used a 14t pnion on the 62spur with factory diffs on 5s and neu 1515 1y geared for about 46 and it was plenty fast and was not under alot of stress , cool running setup. also the reason to use a smaller pinion with such a large spur is that the crt x1 has buggy diff's in it and does not use the truggy diff ratio which is why it uses the large spur.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
