kazuaki
10.01.2009, 02:07 AM
Due to the extended chassis and the location of the standoffs, my battery "compartments" are 142mm long and 44mm wide. The height of the compartments is determined by the length of the standoffs used to seperate the chassis plates, in this case 20mm. I chose these batteries, Zippy Rhino 3S 2550mah 40C/50C.
I made covers that bolt onto the chassis to hold the batteries in place securely and provide a bunch of surface area to mount electronics to. They are made from thin aluminum sheetmetal and weight pretty much nothing.
Almost done
