Finnster
KillaHurtz
Finnster's Avatar
10.01.2009, 04:00 PM
Is this for a 1/10 scale or smaller? You can get away w/ running higher rpms on little motors, where a 5000kv motor for 1/8th scale is a deathwish (and 2500kv not so smart.)
Basically think of it like this, no matter which way you configure the packs, the total available energy stays the same. If you are drawing the same amt of power, the runtime has to be the same (ignoring eff losses.)
Ie
1s6P : 3.7v, 12000mah
6s1P: 22.2v, 2000mah
Both equal 44.4 Wh (watt hours: Amp Hours*volts)
If you draw 4.4Ah/min for your run, you end up with 10mins no matter what.
