GO-RIDE.com
10.01.2009, 06:19 PM
Havoc,
The rotor in your motor may be unbonding from the shaft. It is a very common problem with Tekin T8 motors and Tekin will send you a new improved rotor ASAP. If you can still hear the motor spinning, but the truck is barely moving, then the rotor is going bad.
E-8ight - Tekin RX8 2000kv/4S
