scarletboa
scarletboa's Avatar
10.06.2009, 03:41 AM
Originally Posted by naynay12 View Post
Ok just one last question before i decide what esc to get.With the hobbywing ss 90-100esc you mentioned it starts slow.Does that mean everytime you take your finger off the throttle,and when you apply throttle again it is like a 1 second delay,or does it only happen every now and then?Does it get annoying,or do you get use to it?
the hobbyking 90-100esc works fine as a spare. you get used to the slow startup after a while. it only does it if the motor stops spinning. it got really annoying for me because my non-locked transmission allowed the motor to stop almost instantly. this made controlling the truck in mid-air difficult. if your transmission is locked, or you have a flux transmission, or any setup that gets rid of the one way bearing, it shouldn't be much of a problem. just be sure to program the brakes so they don't engage. there is a link to the website to use when programming in the reviews. for <$30, you really can't go wrong. the esc is rated for up to 7s (some have tried 8s) and 6s lipo won't put the esc at too much risk, unlike the MMM or Tekin ESCs.
