Finnster
KillaHurtz
Finnster's Avatar
10.06.2009, 02:21 PM
IDK absolutely, but I do know you may run into problems w/ the motor hitting the TVP. Its possible it will work if you went to a smaller pinion/spur, but not sure. I got a motor mount from Kershaw Designs that mounts up high, and a medusa motor w/ 16/43 gearing and Cen 2.89 diffs. The motor does fit within the TVPs easily.
The Flux mount requires a 44mm diameter motor (vs 36mm for the medusa.)
At worst, get new TVPs off ebay. They are not very expensive.
