florianz
10.07.2009, 10:18 AM
I try to tell what's in the mag I have found:
"... suddenly the esc didn't work. A bulb was flashing, but Motor didn't work. There is a very small button on the on/off swith, with wich you can calibrate the setup between/of transmitter and receiver. you do it as shown in the manual, afterwards it should be working"
maybe that helps.
there is also something written about problems with reverse in profile 2 and 3
