10.07.2009, 12:57 PM
Hot bodies drive cups are what I used, but finding them ( or any 8mm bore versions for that matter ) is somewhat tricky. I would hit up ebay to start with, search for 'hot bodies'... but specify in the toys & games section, otherwise... well, you can only imagine the results you will get. I'll have a look too when I get home- the work PC doesnt like alot of sites that use flash, and no way to update it withot being an Admin.
As for diff fluid- 7k front & 5k rear is a good starting point, or 5k front & 3k rear maybe if you prefer a bit more diff-action.
