10.07.2009, 02:13 PM
Sounds like a great setup to me, should work just fine, just fine at whooping nitros that is.
5C means you can charge it at 5x the capacity in Ah... so 6.5Ah (6500mah) x 5 = 32 amps. However, no charger yet can do this, the Hyperion 720i can charge that pack at 15 amps though, which is 2.3C, less than half of 5C.
Have you considered going with a 6s lipo setup and a 1500kv. Tekin truggy motor? You would need a 6s/4200mah pack, which I personally use.
