zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.07.2009, 06:08 PM
Nice man, you won't be disappointed with them, they will serve you well even if you don't.
reel, you would want to use a voltage cutoff of no less than 3.2, and 3.4 - 3.5 is preferable for these as these newer packs just hold so much voltage, so you can increase the cutoff the better a pack is, IMO. But, it also depends on your setup as well, when you are geared high and use alot of WOT, or if your pack is not over sized for the application you may want lower the cutoff.
