sikeston34m
sikeston34m's Avatar
10.07.2009, 06:28 PM
Take a look at the 3032 Scorpion Motors on the website.
Here's talk about the bearing. Without something like this, you will have problems with flexing.
"The new version 3032 motors now have an extra ring bearing to support the back end of the rotor can for rock-solid stability. This prevents the shaft from flexing under load, and maintains the airgap between the stator and the magnets under all operating conditions."
If the Shaft will flex on longer endbells, your diff cup WILL flex for sure.
