sikeston34m
sikeston34m's Avatar
10.07.2009, 06:34 PM
Are they all about the same construction Sikes? I know the larger ones use the rotor face instead of the shaft for drive connection, but the guts are the same-ish yes?
Yes, most are the same. Also, most outrunners can drive a prop from either end. By either using a collet on the mount side, or by mounting directly to the rotating endbell.
