jayjay283
jayjay283's Avatar
10.07.2009, 06:59 PM
the 2200 is a larger motor, will run cooler and be plenty fast and you can gear it up (faster) with no heat issues. The 2650 if you put it in a truggy which is basically a monster truck with a center diff will get real hot and you would need/have to find the right gear and the faster KV speed benefit would be negated by the lack of gearing options. Anyone want to help out here or is this payback for when I was a n00b and did this to you all ?
