10.11.2009, 10:19 PM
Most li-po will say to charge at 1c unless otherwise noted on the pack. Zippies are to be charged only at 1c I believe. You are correct in saying that you 3500mah should be charged at 3.5 amps...so a 5k could be charged at 5amp and so on
