Thread: 4s vs 5s
stum
10.14.2009, 06:46 AM
Higher voltage will reduce amp draw in your case because you are limiting the top speed to the same as 4s as long as your not pumping the throttle like the nitro guys do... As you have it you should get longer run times and slightly lower temps, but longer run times will be more noticable than the reduced heat/stress.
