Thread
High speed G-maxx for ISC event, 100mph or bust
Rivermaxx
10.16.2009, 09:40 PM
Got my tires and wheels today they look really good and are really light. Time for some real testing hopfully I can get past 1/2 throttle now. I also noticed on my previouse 59 mph run the pinion gear was loose and spinning on the shaft. I am running 2 6s(22Volts) 3300 mah 30c batterys in parallel for a total of 6600mah and 198 amps continues and 264 amps peak. I am running all 6.5mm bullets capable of handling 200amps. Heres pics of the tires:
Thinking about lengthening the chassis a little more and use a UE mono thunder long steel shaft. But Its alot of work for only ~30 mm more. I wil see how this setup does.
09:42 PM
Rivermaxx
Find all posts by Rivermaxx
