Looks nice river. -
10.18.2009, 06:59 PM
It really does look nice river. I hope the tires hold up for you. I still think a more solid tire might be the ticket for the speeds you want to go. You may have to run your own rubber on a lathe to get a trustworthy set of tires forgetting much over 100mph. So lets see it with the body on there. I sure hope your setup gives you some aerodynamics that will keep the wheels on the road. Once you get up around 80mph it will want to lift up if you do not have some kind of down-force included. Good luck with your testing.
