PBO
RC-Unobtainium
PBO's Avatar
10.19.2009, 05:34 PM
You guys act as if running punch control is putting the MMM past its operating envelope
Punch control is not physical current limiting. Nor does it limit full throttle opperation.
It is just a ramping of PWM value, it does exactly what pulling on the trigger slower would do. just dampens the increase of change from the throttle input. doesnt change anything at WOT
Punch control will be fine... the ramping will deaden the large amp spikes from jerky trigger movement and will help your batteries stay cool.
You really need your cells to be as warm as possible (65-70 degrees C) before a run. You'll get one full power run before most cells loose the window. If you run them cold it'll take a few runs to warm & by then you'll lost the best of the battery
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
