10.19.2009, 10:43 PM
Originally Posted by Rivermaxx View Post
I actually have about 1* toe in in the rear the fronts are neutral also but it is still hard to control. The road crown probably didnt help at all either. I notice under acceleration it started to pull to the left. Whats up with that? If I cruise about 20 mph it goes straight.
sounds like torque steer to me. only thing you could try is flipping diffs and reversing motor operation, but I suspect it may go to the right under acceleration then.
also sounds like you are traction limited, you have a pretty small contact patch with the road. Needs more downforce!
