NickRummy
NickRummy's Avatar
10.20.2009, 12:32 PM
The goal at lunch time today was to get the front ring cleaned up since it still had a lot of center section left. There was no real easy way to do it so out came the dremel with the cut off wheel and a lot of patience.
Here's what I got it trimmed up to. I still need to get it cleaned up but at least I can test it.
So here's the modded Ofna Pirate rim. Outer lip taken off the front and the rear lip completely taken off the back and the front and rear rings from the kong rims.
Here's the slip fit on both sides to see how it goes together. All seems perfect! I'll get the rings epoxied on and should be set.
Now I just need to get the rest all cleaned up and assembled and I think I'll paint them up so they look decent.
