10.21.2009, 10:05 AM
There ya go! If the monster says it is so, then it is so!
People do run the regular MM in buggies (and the MMPro is pretty similar to the MM in current-handling), so 4s should work fine, but it will get warm. 5s on low kv is the way to go.
Or, if you want to use mechanical brakes, run the full 6s and an even lower kv motor (~1300-1500). If you want to retain motor brakes and run 6s, I would solder on an extra TVS/capacitor module to the power wires.
