bdebde
That's All Folks!
bdebde's Avatar
10.21.2009, 03:21 PM
Originally Posted by 88gtanotchback View Post
ok thanks for the tip. is the only downfall to steel drivetrain noise? I think ill try what i have right off the bat and work from there.
Yes the steel gears make a bit more noise, they will wear longer too. Of course a steel pinion on a plastic spur should last forever, just keep replacing the spur as needed. I like the quiet of the plastic spurs, my old buggy is nearly silent under low throttle.
