What's it going to be? Slash 4x4, Hyper 10 SC Pro, Jammin 10 SC ??
stum
What's it going to be? Slash 4x4, Hyper 10 SC Pro, Jammin 10 SC ?? - 10.21.2009, 11:28 PM
Wow I had my pre0rder down on the 4x4 slash when I saw the release... but then I stumbled onto the Jammin 10, then from there ran into detail on the Ofna Hyper 10 SC Pro and now I'm changing my mind....
Tower pre-order has now been canceled..
That Hyper 10 sc pro is leaps and bounds better from what I know if it.. I currently own a Hyper Mini STe and this SC is based totally on that, which is a good thing as the Mini STe rocks, I typically run it w/ 1/10 tires myself.
Ofna SC Pro comes stock w/ 3 diffs, stock w/ cvd's, stock w/ sway bars, aluminum chassis, lower COG, stock w/ proline sc tires, stock w/ aluminum threaded shocks, stock w/ aluminum shock towers, stock w/ aluminum motor mount.. hmm what else could you want? Pretty much the STe extended w/ new bulks and towers and body mounts.. this thing will be a beast on the track!
What are your thoughts?
My guess is the 4x4 SC class will just be a single open class as even the traxxas is stock brushless... so you'll need only to be a SC truck w/ SC tires and a 2s lipo to compete, tweak and mod till your hearts content.
