Originally Posted by redshift
Wow you just don't get it do you? I think it's an awesome feature!
I think I can make it even better! First we'll have a Cox .049 that runs a mini-generator, which will produce power for the glow starter on a .12. Then the .12 will run a generator that charges up the starter pack for the main engine starter motor. After starting the .049 and .12 with a field starter, you will be able to press the start button, and you will be off and smogging up massive acreage! To make things easier, those 3 engines will all use different fuel.
You guys think I should submit this one to Losi's competition, or just apply for the patent now?
Quick get a patent!! Thats GOLD man!!
