NickRummy
NickRummy's Avatar
10.22.2009, 08:59 AM
Hopefully this will be the last of the boring wheel posts
Got the front and rear rings cleaned up and epoxied onto the center section. Drilled a hole and installed my blingtastic valve stems from Summit Racing. You can see the bead of the epoxy around the ring.
The tires are MUCH wider looking. Looks more like a monster truck wheel now.
You can see the difference in the sidewalls pretty well in this pic.
They hold air well but not good enough to hold air over night. Should be fine for testing. Brought the camera and truck with me today so hopefully at lunch time it'll do some floating!
