Rivermaxx
10.23.2009, 09:53 AM
Its fairly flat on the bottom other than the holes cut in the lower plate for the older battery cells the and the front has a slight kick up for adding more caster or camber (what ever its called) . see pic
I plan on using clear packing tape over the bottom holes too smooth them out.
