10.25.2009, 10:15 PM
4600 is a perfect motor for the hpi blitz.. why would you want more? 2s lipo geared right is sick. Tweak w/ the settings if your temps are up a bit and make sure your gear mesh is good. The velineon is a stronger motor and will also do better than fine in this setup. The castle 5700 is ok but no better off than you are now... the 6900 and 7700 are meant for touring cars not offroading expecially racing on a track. I've been running the Medusa 50mm 4800kv on a 2s lipo all summer long... more than enough, I have everything turned down to MIN settings.
