Thread: Kyosho Lazer
Batfish
Batfish's Avatar
01.27.2006, 09:58 AM
Originally Posted by MetalMan
The MGM Compro 12012 is more than enough for a 380C 9t. A MGM Compro 8012 would work just as well (with a lower cost too). This setup would also work well in the Kyosho Lazer.
Although it would work well in the ZX-5, I don't think the MGM controller will fit. Space is VERY limited in competition 1/10th 4wd buggies. I couldn't get either the old-style or new heat sink cube type of MGM to fit my XXX-4 or Academy SB Pro. If you're racing, your best bet for brushless is the Novak GTB system. If not racing, you'll at least need to find a controller with nearly the same footprint as the GTB and the wires from the controller should come out of the top of the controller, not the sides. When the wires stick out of the side of the controller it really limits mounting options in vehicles that are tight on space.
Joe
