ANGRY-ALIEN
ANGRY-ALIEN's Avatar
10.26.2009, 01:09 PM
It continues... I built a little bracket for the heatsink to be bolted to that would fit on the upper plate that didn't appear too intrusive on the design...
... have a look see...
I took the truck to my office parking lot yesterday to put it through passes... I loved the way it performed... it was well balanced and stable despite the surface being wet from a down poor.
I did most of the testing with 16 cells and 14/52 setup... The center diff worked well in keeping the front end on the ground... It just pulled hard through out the rpms until the 14 pinion gave in...
The motor mount screws were loose, so the meshing got messed up. I changed it out for a 16 and tested it on 5s... All I can say is... WOW!!! The hacker came alive...
Keeping the front wheels on the ground was no longer easy (BTW I am using 50K in the center diff). Needless to say, the front tyres are ballooning like crazy now...
Despite all the fun, I'm still a little concerned about the temps... the motor went to the high 160s and esc was floating around 135/140... I might be going back to the 14 pinion
(need to order new ones) to lower the temps on the esc and add a little fan on the motor to try and keep it cooler.
More to come... I hope.
