10.26.2009, 06:51 PM
Well, the MMPro has about the same current capacity as the MM, so, figure ~80A. If the MM runs it, there is no reason the MMPro won't. However, since I assume you'll be running 2s or 3s, you aren't using the biggest advantage of the Pro, which is up to 6s.
