DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
10.27.2009, 10:45 AM
so here's the other question....noting that there is no real standard for testing a C rating and eagletree data sometimes shows these "lower end" packs are a hit or miss, isn't there a determining factor to be considered in MAh too?
for example: X pack is a 10,000 mah 15C pack.... and then you have a 25C 5000mah pack, dosen't the mah have a determining factor for applied power almost the same as the C rating? this, to me is a confusing formula simply because my cheap 10,000mah 15C pack out performs my "high end" 5000mah pack with very similiar cycles.
this makes me hesitate to buy the "higher end" packs that are rated 25-35C but are sometimes below the 5000mah mark. at that point aren't you just splitting hairs between the "lower end" packs and the "higher end" packs?
if someone could explain that one to me it would help clear up alot of confusion.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
